Trans and gear oil? |
04-23-2021, (Subject: Trans and gear oil? ) Post: #1 | |||
Trans and gear oil? What weight should I be using in my 13 speed Eaton and in the rears? | |||
04-23-2021, (Subject: Trans and gear oil? ) Post: #2 | |||
RE: Trans and gear oil? My personal opinion is that 50-wt tranny oil is too thin unless you live in northern canada. I have use 80/90 in mine its whole life. here were the results at 1.4 million miles: http://rawze.com/forums/showthread.php?t...6#pid52116 User's Signature: ->: What I post is just my own thoughts and Opinions! --- I AM Full Of S__T!. | |||
04-23-2021, (Subject: Trans and gear oil? ) Post: #3 | |||
RE: Trans and gear oil? 80/90 here too, no issues, runs and shifts smooth. Just take it easy on the cold mornings until she warms up and all is fine. User's Signature: 2008 ProStar, OEM 600hp CM-871, 18spd, 3:42, in framed in Rawze's driveway. Every day is a fresh new episode of, "The Twilight Zone"... Rod Serling lives rent free in my head. I can smell the Chesterfields. | |||
04-23-2021, (Subject: Trans and gear oil? ) Post: #4 | |||
RE: Trans and gear oil? Will 75w90 work? | |||
04-23-2021, (Subject: Trans and gear oil? ) Post: #5 | |||
RE: Trans and gear oil? It will work, I would not hesitate using it, especially if you have a bunch laying around. User's Signature: 2008 ProStar, OEM 600hp CM-871, 18spd, 3:42, in framed in Rawze's driveway. Every day is a fresh new episode of, "The Twilight Zone"... Rod Serling lives rent free in my head. I can smell the Chesterfields. | |||
04-24-2021, (Subject: Trans and gear oil? ) Post: #6 | |||
RE: Trans and gear oil? With GL-5? | |||
04-24-2021, (Subject: Trans and gear oil? ) Post: #7 | |||
RE: Trans and gear oil? (04-24-2021 )Redland1 Wrote: With GL-5? Do you have emissions on the truck? No emissions, use what you have. As far as the SCR system, if that is operational, I want to say use GL-5, seeing as the Sta-Lube we use in the 871 is GL4 rated. Honestly, I don't think it really matters as long as you do not do extended oil changes. The issue was the soot in regards to the SCR can... I would not be concerned as long as you keep up with the general maintenance and EGR Tuneups. User's Signature: 2008 ProStar, OEM 600hp CM-871, 18spd, 3:42, in framed in Rawze's driveway. Every day is a fresh new episode of, "The Twilight Zone"... Rod Serling lives rent free in my head. I can smell the Chesterfields. | |||
04-24-2021, (Subject: Trans and gear oil? ) Post: #8 | |||
RE: Trans and gear oil? (04-24-2021 )Waterloo Wrote:(04-24-2021 )Redland1 Wrote: With GL-5? It’s an 870 with the EGR still operational (for now). | |||
04-24-2021, (Subject: Trans and gear oil? ) Post: #9 | |||
RE: Trans and gear oil? He's using it in his trans Loo, not in the engine. | |||
