Trans and gear oil? |
04-25-2021, (Subject: Trans and gear oil? ) Post: #19 | |||
RE: Trans and gear oil? 85/90 stalube is $30 a gallon. Seems to be the going rate for quality gear oil. Supertech is cheaper but I don't trust it. That's just how I am though, maybe it's fine. User's Signature: im_seeing_parameters_in_my_sleep 1 | |||
04-25-2021, (Subject: Trans and gear oil? ) Post: #20 | |||
RE: Trans and gear oil? (04-25-2021 )tree98 Wrote: 85/90 stalube is $30 a gallon. Seems to be the going rate for quality gear oil. Supertech is cheaper but I don't trust it. That's just how I am though, maybe it's fine. Supertech is fine, made by Warren Oil, same outfit that produces products for Pennzoil, it meets all of the government standards and is not a recycled product. I have been using it over the Sta-Lube due to price, and when I need it, every Walmart sells it. A gallon is only $14 vs the $40 I last paid for Sta-Lube on Amazon. I'm now a Supertech fanboy, LOL! User's Signature: 2008 ProStar, OEM 600hp CM-871, 18spd, 3:42, in framed in Rawze's driveway. Every day is a fresh new episode of, "The Twilight Zone"... Rod Serling lives rent free in my head. I can smell the Chesterfields. | |||
04-25-2021, (Subject: Trans and gear oil? ) Post: #21 | |||
RE: Trans and gear oil? (04-25-2021 )Redland1 Wrote:(04-25-2021 )Chamberpains Wrote: That's what I've got in both my trucks trans and rears. It's found at fleetpride for a really reasonable price. I think I pay $70-80 a 5 gal bucket at fleetpride. It may be even cheaper when it's on sale | |||
04-25-2021, (Subject: Trans and gear oil? ) Post: #22 | |||
RE: Trans and gear oil? (04-25-2021 )Waterloo Wrote:(04-25-2021 )tree98 Wrote: 85/90 stalube is $30 a gallon. Seems to be the going rate for quality gear oil. Supertech is cheaper but I don't trust it. That's just how I am though, maybe it's fine. The supertech 80w90 I found on Walmart.com is not synthetic.Is that the right one? | |||
04-26-2021, (Subject: Trans and gear oil? ) Post: #23 | |||
RE: Trans and gear oil? (04-25-2021 )Redland1 Wrote: The supertech 80w90 I found on Walmart.com is not synthetic.Is that the right one? It is the one a lot of us use... Is there a particular reason you need only a synthetic? ... or is it just to make yourself feel better by spending more $$ moneys on oil? would depend on your operations and climates that you frequent. -- the next Q. would be "are you replacing all your gearbox oils at 250k miles (or equivalent hours) or every 2 years ... whichever comes first, usually at the same time you re-torque all your hub bearings and do all the other 250k truck maintenance ... like you should be? User's Signature: ->: What I post is just my own thoughts and Opinions! --- I AM Full Of S__T!. | |||
04-26-2021, (Subject: Trans and gear oil? ) Post: #24 | |||
RE: Trans and gear oil? | |||
04-26-2021, (Subject: Trans and gear oil? ) Post: #25 | |||
RE: Trans and gear oil? (04-26-2021 )Rawze Wrote:(04-25-2021 )Redland1 Wrote: The supertech 80w90 I found on Walmart.com is not synthetic.Is that the right one? The only reason I was thinking synthetic was because of the amount of miles between drain intervals.But as far as having a preference I don’t.Motor oil is going to be conventional and the OCI will either be 10 or 12k.Haven’t quite decided on that one yet. Just got the truck.But I will be replacing and re-torquing every 250k going forward. | |||
04-26-2021, (Subject: Trans and gear oil? ) Post: #26 | |||
RE: Trans and gear oil? Well if synthetic is not needed what do y’all think about the Traveller brand of gear oil? | |||
04-26-2021, (Subject: Trans and gear oil? ) Post: #27 | |||
RE: Trans and gear oil? Traveller is also made by warren oil. I have used it in my diffs now for a couple years. | |||
