| Isx15 motor needs more get up and go |
| 04-24-2021, (Subject: Isx15 motor needs more get up and go ) Post: #1 | |||
| Isx15 motor needs more get up and go I’ve got a old tmc truck. Was wondering what to do with it to get more hp and torque with this motor? Should a person delete and who’s the best? | |||
| 04-24-2021, (Subject: Isx15 motor needs more get up and go ) Post: #2 | |||
| RE: Isx15 motor needs more get up and go More than likely it's the load based speed control and their rpm governors that make it feel sluggish. Best bet would be to call haggai diesel repair | |||
| 04-24-2021, (Subject: Isx15 motor needs more get up and go ) Post: #3 | |||
RE: Isx15 motor needs more get up and go (04-24-2021 )Cornbreadtrucker Wrote: I’ve got a old tmc truck. Was wondering what to do with it to get more hp and torque with this motor? Should a person delete and who’s the best? * what is the current HP/torque? * What is the rear-end ratio?. Many fleet trucks are geared completely wrong these days, they cannot get out of their own way, and eat the liners out of the ISX due to lugging the engine below 1500 rpm's everywhere. Those tall rears that a lot of trucks have these torture the ISX forcing low rpm all the time, cut engine lifespan in half. * What make.model/year truck? ... engine? * What have you done to the truck to keep the engine healthy besides changing the oil?.. things like regular egr tune-ups?, regular overhead valve adjustments?, * How many miles on engine?. Has the fuel pump guts been replaced at the 400k mile mark? * Will it pass an injector leak test? * What program is in the ecm?. For all you know, the program itself may have all the garbage like load based speed control and smart-torque2, etc.. turned on to hold it back like most company trucks these days. * Some history? and what type of operations? -- BTW: you got a rude awakening ahead of you if your mentality is that of "Who's the best"... vs... "Who's not going to destroy my engine"... as most all places that do that type of work are way beyond horrible, and most ppl that have that type of work done do nothing but trade DPF issues out with severely shortened engine life and repeated engine failures because of it. There are many reasons that an engine will be sluggish... not just its power/torque rating. Also.. if the truck is geared wrong for the operations (many trucks these days are geared horribly wrong) .. then the engine is the LAST thing you want to adjust to overcome it... IT IS THE MOST EXPENSIVE THING IN THE DRIVE-TRAIN. RE-GEARING THE TRUCK is ALWAYS the cheaper investment and has the most gains. ... IMPROVING THE GEAR RATIO OF THE VEHICLE IS THE PROPER SOLUTION!... and not trying to work the most expensive thing in the drive-line (the engine) harder. -- and just a warning that if anyone reading this is one of those complete stupid-trucker-morons who wants big power, brag about how many HP they got, and wants to go up the hills in top gears.. They will quickly find themselves kicked off this forum real fast!. Just a warning to those who are hell bent on big power.. This place is about making money you can keep and doing things the right ways ... Not how to tear your s#it up!... No one on here is going to promote, nor help others do stupid s#it like that to their equipment. User's Signature: ->: What I post is just my own thoughts and Opinions! --- I AM Full Of S__T!. | |||
| 04-24-2021, (Subject: Isx15 motor needs more get up and go ) Post: #4 | |||
| RE: Isx15 motor needs more get up and go Truck is a 2014 579 Peterbilt with a isx15 cummins set at 455hp 1650 torque I had Tramission converted to a 13 from a 9 it’s got 3:42 rears. Motor rebuilt 170,000 miles ago it’s got 673,000 on truck I don’t want a ground pounder I just want little more pulling power and it don’t have to be deleted. Overhead ran 2 months ago. | |||
| 04-24-2021, (Subject: Isx15 motor needs more get up and go ) Post: #5 | |||
RE: Isx15 motor needs more get up and go (04-24-2021 )Cornbreadtrucker Wrote: Truck is a 2014 579 Peterbilt with a isx15 cummins set at 455hp 1650 torque I had Tramission converted to a 13 from a 9 it’s got 3:42 rears. Motor rebuilt 170,000 miles ago it’s got 673,000 on truck I don’t want a ground pounder I just want little more pulling power and it don’t have to be deleted. Overhead ran 2 months ago. First, the motor, what is it, a 455st or a 455? I am assuming a 455st. And I am assuming it is a CM-2350 motor? Open a Cummins Quickserve account, you will need the ESN or EIN (Engine Serial/Identification Number) off of the motors data plate, which is found on the valve cover on the driver side of the motor. You will need the EIN to open this free account, and it will give you access to everything regarding your motor, from trouble shooting to complete engine tear down and assembly, along with an entire parts list with part numbers, this is the same information that Cummins uses in their shops, we have full access, use it, do that right now. https://quickserve.cummins.com/info/index.html Also, regarding the program settings from TMC that may still be lingering in the ECM, if you are going to keep this truck, you will need the Cummins Inline 6 reader and the Insite software, I would recommend ordering that right now, most all of us purchased ours on eBay, around $300 for the kit, here is a link to one... https://www.ebay.com/itm/254353420216?ha...SwG4Be7xPe Another thing you can do while you await the Inline reader kit from eBay, is take the truck to the local PACCAR dealer and have them update the ECM software to the latest available from Cummins, have them put the standard factory program in, overwriting what TMC has installed. I would do that, as then you have the most up to date software which should turn off any of those terrible settings TMC has installed if they are still there. Now you have a clean slate to work with, and I would not think twice about having that work done, just do it. They normally charge a few hundred dollars, do it. Your other issue is the gearing in the rear end, I have the same gearing in mine. You can overcome many of the issues if you can keep the rpm above 1500. In mine, I normally run in the 1600 to 1900 range, and use the instant mileage readout, along with the turbo boost gauge to monitor fuel economy. I try to run the boost between 0 and 12 psi, let the engine do the work, not the turbo. I have found that running between 55 and say 63 mph is where I have the most power and fuel economy. DO NOT lug this motor, or you will be in serious trouble, to the tune of tens of thousands of dollars when a liner busts loose and you take out the head. When under a load, KEEP THE RPM ABOVE 1500 RPM! This is what happens, you lug that motor with a load, say down at 1200 or 1350 rpm, the motor is now fighting against itself internally. This is due to the engine design, when you lug the motor the lateral force of the pistons and rods puts undue pressure on the cylinder, or liner walls. The liners sit on a very tiny ledge, about 3/16th of an inch. The only thing holding these liners in place is the weight of the head and that tiny lip they sit upon. You lug the motor, you are now hammering those liners loose, they fail, and it is in frame time. With your 13 speed, I would run that in high seventh gear for the best performance. And stay away from the cruise control. About the only time I will use mine is bob tail or in the flats with an empty trailer with a tailwind. As far as moving away from a traffic lights or stop signs, only fix there is to re gear, 3:55 or 3:70ish, depending on what you are doing. Me, I can live with mine, as I do not care anymore and am not in a hurry, so I live with it and compensate with my transmission. The fuel savings alone is worth it to me to go slow and steady, you can easily shave hundreds a week off of your fuel bill by running like I do, and others here. Now, the motor itself, I assume you still have the emissions? I hope you do, there are too many butchers out here as Rawze stated, you want a clean slate to work with, and not some butchered up piece of equipment. The EGR tuneup, do that now too, replace the Intake Manifold Pressure Sensor and the Exhaust Back Pressure Sensor. I would assume you will need a proper overhead, or valve adjustment, that is something these outfits like TMC rarely ever do, they are simple to do with the correct tools, there is a video in the video link at the top of the page on how to do one correctly. Now, the monster in the room, the FUEL PUMP! If that is still painted red, you are driving a ticking time bomb. Myself, I would have it rebuilt, or do it yourself. These pumps are still failing and taking out motors, like boat anchor damage, destroying the block and crankshaft. Nothing to play with, rebuild every 400,000 miles, or sooner. I would do that now too, rebuild it or replace with a new one, so that YOU KNOW exactly when it was rebuilt and can prepare to do it again down the road, do not tempt fate and ignore this pump. The mandate, myself, I would go see Mr Hagg and let him fix your truck, fix the programming, install the proper gauges, run the overhead, etc... Let him go over the motor. He is located just South of Atlanta in Griffin GA. Mr Hagg is the only shop I would trust in this country to do this work. Haggai Automotive and Diesel Repair 1228 High Falls Rd, Griffin, GA 30223 Hours: Opens 8AM Mon Phone: (678) 688-8107 I know, this is a lot to chew on, take it one step at a time, grab this bull by the horns before it bankrupts you. I don't know how old you are, or how long you have been in this trucking or owner operator racket, but these trucks are not the same ones I started with back in the late 80's. Changing oil, greasing them and general maintenance are now a thing of the past, these are complicated machines, but easily understood with a bit of study. Me, I would take the truck to Mr Hagg, that is your least painful option, but still purchase the Inline reader and software, as that will keep you out of the shops and away from the thieves that populate those places. Many times a sensor will fail, you go the dealer and they will insist it is a bad turbo or EGR Cooler, they can clean you out in a few seconds, when all you needed was a $55 sensor that is easily diagnosed using the Insite software, that kit just paid for itself. OK, I'm done... We are here to help, take advantage of the years of experience here, and trust me, most all of us have our own horror stories regarding these Red motors, use our knowledge to your benefit, and welcome aboard! User's Signature: 2008 ProStar, OEM 600hp CM-871, 18spd, 3:42, in framed in Rawze's driveway. Every day is a fresh new episode of, "The Twilight Zone"... Rod Serling lives rent free in my head. I can smell the Chesterfields. | |||
| 04-24-2021, (Subject: Isx15 motor needs more get up and go ) Post: #6 | |||
| RE: Isx15 motor needs more get up and go Im sure that 1650 is prty anemic especially with smart torque and load based active. | |||
| 04-24-2021, (Subject: Isx15 motor needs more get up and go ) Post: #7 | |||
| RE: Isx15 motor needs more get up and go I appreciate the links and the suggestions on the shop I will call him on Monday to get set up with him I been working right outta the area actually. As for the motor I will get the serial number tomorrow off the motor. The fuel pump was taken apart and checked back in the winter it has been rebuilt with the new style parts. I’m glad you told me about the RPMs cause I do tend to run it 1500 or under. Guess I’ll need to change my driving habits lol. | |||
| 04-25-2021, (Subject: Isx15 motor needs more get up and go ) Post: #8 | |||
RE: Isx15 motor needs more get up and go (04-24-2021 )Cornbreadtrucker Wrote: I appreciate the links and the suggestions on the shop I will call him on Monday to get set up with him I been working right outta the area actually. As for the motor I will get the serial number tomorrow off the motor. The fuel pump was taken apart and checked back in the winter it has been rebuilt with the new style parts. I’m glad you told me about the RPMs cause I do tend to run it 1500 or under. Guess I’ll need to change my driving habits lol. That is good to hear, you can get the truck over to Jerry's shop, Mr Hagg. He will be your best bet, he will not lie to you or empty your wallet for unneeded repairs and what not. Jerry, his family and crew are fantastic folk's, I've been to the shop, and they have worked on my truck. Maybe Rawze will stop by, he is up there every now and then. Good luck on your new venture, follow the advice here and you should be successful! And yes, change the driving habits. ;-) User's Signature: 2008 ProStar, OEM 600hp CM-871, 18spd, 3:42, in framed in Rawze's driveway. Every day is a fresh new episode of, "The Twilight Zone"... Rod Serling lives rent free in my head. I can smell the Chesterfields. | |||
| 04-25-2021, (Subject: Isx15 motor needs more get up and go ) Post: #9 | |||
RE: Isx15 motor needs more get up and go (04-24-2021 )Cornbreadtrucker Wrote: ...The fuel pump was taken apart and checked back in the winter it has been rebuilt with the new style parts. ... so was it rebuilt with new guts at that time when it came apart?.... or just simply checked and put back together? User's Signature: ->: What I post is just my own thoughts and Opinions! --- I AM Full Of S__T!. | |||
