X15 air compressor Intake relocation.
08-15-2021, (Subject: X15 air compressor Intake relocation. )
RE: X15 air compressor Intake relocation.
(08-14-2021 )Rawze Wrote:
(08-14-2021 )schISM Wrote:  This setup is on my Peterbilt. If you can get the parts it draws from just ahead of the turbine.
like 'marek4792' mentioned .. I think that is a terrible place to put that.
Oh...ok I had to reread the post a few times. So Marek how did you end up plumbing your compressor intake? Seems locating the intake in the air cleaner tract isn’t the issue just getting rid of the factory piping that’s prone to failure.
I ended up keeping the last 90 degree silicone tubing and getting a 1 1/4 inch breather filter.
 Thanks given by: schISM
