A/C idler pulley play
09-02-2021, (Subject: A/C idler pulley play )
Is the a/c idler pulley supposed to have a little give to it? The old one (original) had some, too. But not quite as much.
https://youtube.com/shorts/eh08IjkcDe4?feature=share
RE: A/C idler pulley play
(09-02-2021 )Mrkentee Wrote:  Is the a/c idler pulley supposed to have a little give to it? The old one (original) had some, too. But not quite as much.
Just couple hours ago did my belts. My old 910,000 miles has no play at all.
 Thanks given by: Mrkentee
That’s weird. Old one had 1.2 million. Once it has pressure on it, it seems ok.
makes a person wonder if that play is in the bearing itself ... or play in how its mounted. If it is play in the mount and not the bearing, then it is likely going to fail at some point... and if it is in the bearing,.. then that must be one crappy quality bearing.
Mine has no play in it .. It is an original OEM idler from the engine maker, and it has a grease-less sealed bearing. I have seen some aftermarket idlers with a lot of play in them due to cheaper bearings.. but have not seen an issue with them per say though either, as long as they are sealed properly and the grease does not run out.
just some observations.
(09-02-2021 )Rawze Wrote:  makes a person wonder if that play is in the bearing itself ... or play in how its mounted. If it is play in the mount and not the bearing, then it is likely going to fail at some point... and if it is in the bearing,.. then that must be one crappy quality bearing.
Same exact bearing. I measured it with calipers, also. The sleeve that goes in from the back only reaches about half way through the bearing or so. The pulley itself is from Gates. Made in Canada.
I better check it again.
It was put together in this order. The dust cover acts as a spacer. I wonder if it was put together wrong. I can’t find a diagram on Quickserve.
that NTN bearing should be of decent quality... should not have very much play in it. Check your mounting to ensure there is no play in the mount itself any ways.
Big Grin RE: A/C idler pulley play
(09-02-2021 )Rawze Wrote:  that NTN bearing should not have very much play in it.
It doesn’t have support all the way through. The sleeve only goes so far, which is weird.
I put the old one back on for now.
the inner bearing race should be held tightly when the retaining bolt is at its proper torque setting.
