Steer hub cover
09-21-2021, (Subject: Steer hub cover )
Steer hub cover
My truck a 2003 International 9900 has this hub cover on the steer axle and I’m wondering if it’s an oil bath since it doesn’t have a fill hole in the middle and different from the ones I’m used to.
RE: Steer hub cover
It is a unitized hub, there is no fixing or maintenance and you will have to replace the hub as whole if there is an issue.
 Thanks given by: Redland1
09-22-2021, (Subject: Steer hub cover )
RE: Steer hub cover
(09-21-2021 )Volvo8873 Wrote:  It is a unitized hub, there is no fixing or maintenance and you will have to replace the hub as whole if there is an issue.
How can I tell when there is an issue with one of these?
RE: Steer hub cover
Jack it up, remove the tire, and check the end play .. and the up/down play in the hub with a Dial indicator.. as specified in the hub service manual.
 Thanks given by: Redland1 , Pd6cas2
