Thermoster mod
09-30-2021, (Subject: Thermoster mod )
Thermoster mod
Ok here is my fix for the thermoster replacements.
I used 2 old thermosters and gutted them. Then I got a 90° hydraulic fitting and cut off the threads. I also got 2 12mx1 nuts. And welded the pieces as seen together. The gutted thermosters act as plugs and the nuts are to put new thermosters in I also added some heat transfer past in the fittings. Lastly I plan on heatshrinking the fittings and adding some pipe insulation over that. So now when I change out the thermosters I don't need to vac and refill the system..
RE: Thermoster mod
WoW .. that looks pretty good ... you should manufacture them and sell them to all Prostar Owners to help alleviate their A/C nightmeres!!.
Why the h#ell could International not have done something like this to begin with, I have no idea!.
