Cm2350 X101 egr coolant line part number
12-03-2021, (Subject: Cm2350 X101 egr coolant line part number )
Looking to find the part number for a demandated cm2350 x101 for the coolant line that replaces the egr cooler for a country that does not have emmisions.
RE: Cm2350 X101 egr coolant line part number
(12-03-2021 )Luckyjayb Wrote:  Looking to find the part number for a demandated cm2350 x101 for the coolant line that replaces the egr cooler for a country that does not have emmisions.
drawing 'bb1906-04' on quickserv.com shows whats needed it I think.
 Thanks given by: Luckyjayb
12-04-2021, (Subject: Cm2350 X101 egr coolant line part number )
No luck on my part for that.
(12-04-2021 )Luckyjayb Wrote:  ...
I'm looking right at it...
https://quickserve.cummins.com/qs3/porta.../bb1906-04
./uploads/202112/post_2_1638623891_b6b1ac23b8b1076f653674eaea64a596.png
I actually found it with a Google search and it was posted by you!
