C12 cat |
12-07-2021, (Subject: C12 cat ) Post: #1 | |||
C12 cat I have a c12 cat. Startup above 40degs hardly any smoke, below 40degs raw fuel smoke & smell. Fires right up not even a full revolution. Runs smoother cold and rougher when hot outside. When the air compressor builds air the motor surges until the air pops off at 125psi. Guy i got it from had a new ecm and cam put in the truck in Feb. 2021. Ecm was done at a private shop. Any ideas where to start with this? | |||
12-07-2021, (Subject: C12 cat ) Post: #2 | |||
RE: C12 cat start by putting the factory program file that is made for that ser# engine, and put back the factory trim codes back in it that match the injectors. Leave the ecm programming alone after that. User's Signature: ->: What I post is just my own thoughts and Opinions! --- I AM Full Of S__T!. | |||
12-07-2021, (Subject: C12 cat ) Post: #3 | |||
RE: C12 cat I will do this rawze. Best to have a dealer do it like Cat or stealership? I just want it stock 430hp anyway. | |||
