Great Tool Set for your Truck!
02-27-2016, (Subject: Great Tool Set for your Truck! )
I picked up this tool set at Lowes in Texas for $99 http://www.lowes.com/pd_573343-25428-867...l+sets#img
It has been a life saver, it has the torx and allen head sockets, along with 3/4 drive for larger stuff. The case is heavy duty and has solid hinges with metal pins. If you are in the market for a new set of tools for the truck, this set is as close to perfect as I have found in regards to fitting easily into the truck, supplied tools and solid construction. I have used these tools for all sorts of stuff on the truck, nothing in this kit has failed me.
I supplemented with ratcheting wrenches and other sockets and such from Sears. Put all of them in a blow molded long narrow case that Sears also carries.
If you ever find yourself in need of a cordless drill, this little Dewalt is the BOMB! http://www.amazon.com/DEWALT-DCD710S2-12...t+DCD710S2
It charges quick, has a nice soft case and two batteries. This has saved me allot of time and grief having this baby on the truck. It is small, stores easily and packs a punch for such a small drill/driver.
I hope this helps!
