Shocks
08-24-2016, (Subject: Shocks )
Post: #19
RE: Shocks
My truck has a Hendrickson HTB LT suspension. Anybody know if I can use the Gabriel shocks mentioned above?
06-05-2021, (Subject: Shocks )
Post: #20
RE: Shocks
I used Gabriel’s. They make an adjustable that is awesome!!!
06-06-2021, (Subject: Shocks )
Post: #21
RE: Shocks
(08-24-2016 )CFR__AND_SONS Wrote:  My truck has a Hendrickson HTB LT suspension. Anybody know if I can use the Gabriel shocks mentioned above?
Just make sure the replacement shocks have the same max stroke length.
 Thanks given by: Toolguy
Post: #22
RE: Shocks
What Rawze said!! I learned this the hard way on my stepdeck trlr. Brand new monroe shocks completely torn in half in a 600 mile move. Yes, max and minimum stroke length matter. Though they may visually look the same that couple digit part number discrepancy may mean the world. Hahaha
 Thanks given by: JimT
Post: #23
RE: Shocks
The Gabriel’s are made for the truck application. You can search their website for the correct model for your truck.
