N14 Celect Plus Timing Specs CPL 2592 525 HP
02-16-2022, (Subject: N14 Celect Plus Timing Specs CPL 2592 525 HP )
RE: N14 Celect Plus Timing Specs CPL 2592 525 HP
I’m gonna tell ya, it’s been a while since I’ve had to do one and it’s trying me!!!
02-17-2022, (Subject: N14 Celect Plus Timing Specs CPL 2592 525 HP )
(01-06-2022 )RocketScott Wrote:  I have the timing tool and extra gaskets if you need it
Well almost got it jigged but the previous “Cummins” tech put cam followers on it for a mechanical n14 rated up to 400hp. Had to order a new set of cam followers.
04-05-2022, (Subject: N14 Celect Plus Timing Specs CPL 2592 525 HP )
The shop that pulled my engine and put the new one in said they had an N14 that they couldn't get timed. They didn't really explain why but I think it had something to do with the followers. Guessing they made different lengths for later engines than mine
Not sure if changing the cam key would allow the old followers to work in the newer engine
All just guessing on my part, I don't know much about newer engines than mine
