CM871 fuel pressure delivery
01-14-2022, (Subject: CM871 fuel pressure delivery )
RE: CM871 fuel pressure delivery
I have 3 codes that are active they are
0547. 2215. 2372
(01-14-2022 )Skinny6 Wrote:  I have 3 codes that are active they are
0547. 2215. 2372
547 = fuel pressure low.
2215 = fuel pressure too low from pump.
2372 = fuel filter clogged. restriction in fuel filter detected.
You have changed your fuel filter lately right??
01-15-2022, (Subject: CM871 fuel pressure delivery )
Yup sure have it's the first thing I did when this problem started
Try checking the fuel pickup lines to the fuel tanks for leaks. Add a clear line to the suction side of the elctric pump or filter and check for air bubbles.
