| Fuel rail relief valve psa |
| 03-01-2022, (Subject: Fuel rail relief valve psa ) Post: #1 | |||
| Fuel rail relief valve psa Got a 1239 code yesterday for excess fuel leakage turns out my 16 month old pressure safety relief valve has already failed to the point where there's a steady stream out of it at idle . Probably a table spoon every 2 seconds or less. Also had a few drops come out the line that connects to it so one of my quill tubes must have a small leak. So ied recommend checking this every couple months on your 22-2350 and x15s takes about 1 minute with the correct socket 2 min with a crescent or wrench User's Signature: 2010 Lonestar - CM871 - 13sp - 3.70s, 2016 T680 - cm2350 - 13sp - 3.36s - skateboarder | |||
