Relay by ecm, behind intake manifold
03-17-2022, (Subject: Relay by ecm, behind intake manifold )
Still searching for the starter relay. Found a relay to the right of the ecm behind the intake manifold. I thought this has got to be it. Pulled it, and turned the key, expecting nothing. And it started right up.
Does anyone know what that relay is for? It’s a big one on the end of a few wires, all by itself.
There were no check engine lights.
Thanks
RE: Relay by ecm, behind intake manifold
Electric Lift pump
 Thanks given by: Mrkentee , Rawze
(03-17-2022 )Nostalgic Wrote:  Electric Lift pump
Yeah, I think you’re right. Thanks
