Oil change and now high psi cm870
05-08-2022, (Subject: Oil change and now high psi cm870 )
Just had the oil changed and my psi is at 51 on the gauge and on Insite while idling.It’s usually at 40 or a little under while driving.04’ cm870
RE: Oil change and now high psi cm870
maybe start by replacing/verifying the oil pressure sensor?.
 Thanks given by: Redland1
05-09-2022, (Subject: Oil change and now high psi cm870 )
https://imgur.com/a/WYaakID
Oil psi gauge acting strange with truck off and key on.You can also see when I turn it on it it moves up to 80 and then back down.
