| Water pump |
| 05-27-2022, (Subject: Water pump ) Post: #1 | |||
| Water pump My water pump is original with 1,285,883 miles on it. It doesn’t leak, and I have no complaints. Should I be concerned? I have a new OEM cartridge I carry around if it should start leaking. I change my coolant every year. I’m not worried about it, but every once in a while I read something that makes me think twice. ?? | |||
| 05-27-2022, (Subject: Water pump ) Post: #2 | |||
| RE: Water pump With 1+ million miles on it .. Maybe rebuild or replace it the next time you have to replace the fan clutch or have to remove the drive belt?. User's Signature: ->: What I post is just my own thoughts and Opinions! --- I AM Full Of S__T!. | |||
