Hard Clutch and grinding noise
06-18-2022, (Subject: Hard Clutch and grinding noise )
Hi good morning,
I have Peterbilt 587 2014 Cummins ISX
Was going to down the road and the hydraulic clutch went super hard while driving was still working.
Truck was driving fine. 800 miles later a grinding noise started
And when clutch is depressed it sounds like air is leaking out. It’s making noise in neutral also
Currently Le Grande Oregon
Trying to look for the leak right now
RE: Hard Clutch and grinding noise
not good.
Oh it’s not good. Found broken pieces inside. Taking it to the shop down the road
11-16-2022, (Subject: Hard Clutch and grinding noise )
(06-18-2022 )Shokar92 Wrote:  Oh it’s not good. Found broken pieces inside. Taking it to the shop down the road
Have to replace the the whole clutch ? What did it end up being exactly ?
