vacuum coolant refil
09-01-2022, (Subject: vacuum coolant refil )
Hello, i did my first vacuum coolant refill today. But maybe I did something wrong. My pipe which goes to top of Radiator stayed collapsed after all coolant went in. And only after I added some air into the system it come back to normal shape. What I did wrong?
09-02-2022, (Subject: vacuum coolant refil )
RE: vacuum coolant refil
its fine... but it likely also shows that hose it possibly getting worn out.
 Thanks given by: Konstantin
09-03-2022, (Subject: vacuum coolant refil )
Thanks a lot! Yes hose is old.
