CM871 EGR Valve.
09-15-2022, (Subject: CM871 EGR Valve. )
CM871 EGR Valve.
What sensor controls the EGR valve on a CM871 ISX15.
RE: CM871 EGR Valve.
There is no specific sensor that controls the valve. The ecm uses a bunch of different data to determine how much to open the valve. I think what you might be after is the egr temp sensor plug which disables egr opening when unplugged.
 Thanks given by: hhow55
