RAE Reman Injectors
09-06-2016, (Subject: RAE Reman Injectors )
RAE Reman Injectors
Reman Auto Electronics offers heavy duty injectors remanufactured by Flight Diesel for the Cummins ISX. Has anyone bought from them and if so what was your experience?
http://www.remanautoelectronics.com...utm_term=433&gclid=CPn1waT2-84CFYQ9gQod850Nlg
Cummins keeps increasing the price on injectors, last week they were over $600!
RE: RAE Reman Injectors
That's nothing man! Try $950 per injector for the cm2250 and cm2350
09-07-2016, (Subject: RAE Reman Injectors )
My own take on re-man injectors...
http://rawze.com/forums/showthread.php?t...67#pid4367
I wouldnt pay $600 for a Cummins reman. I have an injector shop I use that does a fine job. Who knows.....Cummins is probably sending him injectors to rebuild. I can tell you that Cummins did a horrible job supporting the N14 and I have no doubt they will do the same for the ISX 870 and 871. If you want to know the shop look at the link Rawze gave above....we argue a bit. My shop does them for $450 and when I dropped them in they worked fine.
