|  Causes of excess blowby  |
|  10-05-2022, (Subject: Causes of excess blowby )  Post: #1 | |||
| Causes of excess blowby  cm870- ive had this truck since 850k miles, now has 1.4mil . Has had 2 set of pistons/liners put in since i bought it, and it has always had quite a bit of blowby. can a wore out air compressor create blowby ? i dont even pay attention to it anymore but after holding the steering wheel all day today i just started thinking about it... and i made one of them test tube things like in the manual for checking blowby pressure, and mine was always worse than they say is "acceptable" | |||
|  10-05-2022, (Subject: Causes of excess blowby )  Post: #2 | |||
| RE: Causes of excess blowby  In quickserve you will find in sympton search under High Blowby info that should be of help.  User's Signature: It's hard to win an argument with a smart person, but it's damn near impossible to win an argument with a stupid person | |||
|  10-06-2022, (Subject: Causes of excess blowby )  Post: #3 | |||
| RE: Causes of excess blowby  Air compressor, turbo, valve stem seals or cylinder issues are all possible causes.  | |||
|  10-06-2022, (Subject: Causes of excess blowby )  Post: #4 | |||
| RE: Causes of excess blowby (10-05-2022 )Badger Wrote: cm870- What I would like to know is why it has had 2 sets of pistons and liners in only 550k miles?. Something does not sound right at all if that is the case.. and was all OEM parts used?// was a new head used?... were the liners raised to 0.015"?... and did anyone double-ensure that the rings were all set correctly (180-degrees away from each other properly) as the pistons went in?.. those are the things that come to mind when I read your post. User's Signature: ->: What I post is just my own thoughts and Opinions! --- I AM Full Of S__T!. | |||
|  10-06-2022, (Subject: Causes of excess blowby )  Post: #5 | |||
| RE: Causes of excess blowby  What the guys above said.... and does this truck happen to have a hot file in it?  | |||
