|  2013 IXS15 CM2350 Rod & Main Bearings  |
|  11-17-2022, (Subject: 2013 IXS15 CM2350 Rod & Main Bearings )  Post: #1 | |||
| 2013 IXS15 CM2350 Rod & Main Bearings  I'm coming up on my 800k mile mark and it's time to replace the low end.  Do any of you have the Cummins kit #'s for the Rods and Main Bearings? Yes I will probably end up buying them directly from Cummins, but I'd like to at least see how much they're gigging me for above their competition. And aside from these two kits and oil pan gasket, is there anything else I will need from Cummins? | |||
|  11-17-2022, (Subject: 2013 IXS15 CM2350 Rod & Main Bearings )  Post: #2 | |||
| RE: 2013 IXS15 CM2350 Rod & Main Bearings  You can order them from cummins online and you can get 20% off for cyber Monday this coming week. I sometimes get my parts the next day.  User's Signature: Born and raised in Vyskonsin on milk, cheese, bread, and beer! | |||
|  11-17-2022, (Subject: 2013 IXS15 CM2350 Rod & Main Bearings )  Post: #3 | |||
| RE: 2013 IXS15 CM2350 Rod & Main Bearings  JUST MAKE SURE YOU VERIFY EACH BEARING PART# as they come out.. cummins is known to occasionally have an odd bearing size randomly in their engines (to make clearance corrections) as they go down the assembly line. 80% it is all standard size bearings.. 20% chance you get one lobe with an odd fit one randomly.  User's Signature: ->: What I post is just my own thoughts and Opinions! --- I AM Full Of S__T!. | |||
|  11-17-2022, (Subject: 2013 IXS15 CM2350 Rod & Main Bearings )  Post: #4 | |||
| RE: 2013 IXS15 CM2350 Rod & Main Bearings | |||
|  11-18-2022, (Subject: 2013 IXS15 CM2350 Rod & Main Bearings )  Post: #5 | |||
| RE: 2013 IXS15 CM2350 Rod & Main Bearings  In futile attempts to understand exactly what parts (kits) are required via QuickServ I finally broke down and emailed Cummins directly with my ESN and need. As far as promo code or discounts I have seen nothing on their website regarding this, but I will ask them about that as well. Will report back once they respond. | |||
|  11-18-2022, (Subject: 2013 IXS15 CM2350 Rod & Main Bearings )  Post: #6 | |||
| RE: 2013 IXS15 CM2350 Rod & Main Bearings  http://app.noreply.cummins.com/e/es?s=14...49&elqat=1 Bought a crankshaft dampener earlier this year with the Memorial Day one they had. It was free shipping to my door and took only 2 days. I actually buy all my parts from them online when permitted. User's Signature: Born and raised in Vyskonsin on milk, cheese, bread, and beer! | |||
|  11-18-2022, (Subject: 2013 IXS15 CM2350 Rod & Main Bearings )  Post: #7 | |||
| RE: 2013 IXS15 CM2350 Rod & Main Bearings  Awesome thanks for sharing!  | |||
|  11-18-2022, (Subject: 2013 IXS15 CM2350 Rod & Main Bearings )  Post: #8 | |||
| RE: 2013 IXS15 CM2350 Rod & Main Bearings  I just talked with support over there at cummins online. He said there is a promo code for this sale, it will be advertised on cyber Monday(Nov. 28) and will only be good for that day.  | |||
|  11-20-2022, (Subject: 2013 IXS15 CM2350 Rod & Main Bearings )  Post: #9 | |||
| RE: 2013 IXS15 CM2350 Rod & Main Bearings  I don’t believe Cummins sells a kit for rod bearings. Only mains. Rods you need to buy 6 individual sets.  | |||
