Borescope... Anyone use a Milwaukee unit? Or the Rigid?
01-05-2023, (Subject: Borescope... Anyone use a Milwaukee unit? Or the Rigid? )
This Rigid unit... https://www.homedepot.com/p/RIDGID-CA-25.../203258908
Or this Milwaukee unit... https://www.homedepot.com/p/Milwaukee-M1.../202932657
I don't know, is it even worth it to look into the water jacket of this abortion I am working on? The Milwaukee unit, the end of the scope, looks a bit to long to get in there, where the Rigid looks quite a bit more compact.
Have any of you used either, or can recommend one that would be locally available in a major area, say from FleetPride or other automotive chain stores.
RE: Borescope... Anyone use a Milwaukee unit? Or the Rigid?
I dont know if you have a menards store near you, but I have one from a brand called "masterforce" that I paid like 120-130 for that works pretty well. It's a house brand kinda thing. At the shop I use a snap on boroscope that I scored cheap off the matco truck that someone traded in. Pretty nice and the camera is wireless from the screen.
I will look it up... Thanks for the heads up. Found it... https://www.youtube.com/watch?v=P75UT95DsVQ
I doubt you'll see much in the water jacket. Any silicone that got in there is probably stuck in the radiator.
01-06-2023, (Subject: Borescope... Anyone use a Milwaukee unit? Or the Rigid? )
Agree, just a thought, I will be better off with a shop vac at this point. Going to g grab that little one out of my truck on the way in.
