HORRIBLE fuel mileage |
02-05-2023, (Subject: HORRIBLE fuel mileage ) Post: #19 | |||
RE: HORRIBLE fuel mileage (02-05-2023 )Redland1 Wrote: I don’t have the file and have been told that if you try to pull it from a cm870 it corrupts the file You can copy it out. It's changing it and putting it back in that can be a problem. User's Signature: im_seeing_parameters_in_my_sleep 1 | |||
02-05-2023, (Subject: HORRIBLE fuel mileage ) Post: #20 | |||
RE: HORRIBLE fuel mileage | |||
02-05-2023, (Subject: HORRIBLE fuel mileage ) Post: #21 | |||
RE: HORRIBLE fuel mileage Do you have C A L T E R M ? User's Signature: im_seeing_parameters_in_my_sleep 1 | |||
02-05-2023, (Subject: HORRIBLE fuel mileage ) Post: #22 | |||
RE: HORRIBLE fuel mileage (02-05-2023 )Redland1 Wrote:(02-05-2023 )tree98 Wrote: Did you pressurize the whole engine from turbo inlet to turbo outlet? That's the only way to find every possible leak. That is excessive boost. It needs to be about 37~ish max. 40+ will eventually cause harm to the engine and also cost it fuel mileage. If it was someone from the forum here that made the program, then you need to get with them and have them lower it down to something more reasonable. User's Signature: ->: What I post is just my own thoughts and Opinions! --- I AM Full Of S__T!. | |||
02-05-2023, (Subject: HORRIBLE fuel mileage ) Post: #23 | |||
