Egr temp high isx 15 |
02-18-2023, (Subject: Egr temp high isx 15 ) Post: #1 | |||
Egr temp high isx 15 Hi folks 2013 isx 600 Cm2250. Stock. Have fc 2962 for high egr temp. I plugged in insite and even when truck is off it is showing 600 deg egr temp. Exhaust gas temp varying between 80-250 once on. Is this likely a sensor issue because of that data being stuck at 600 deg for egr temp. I believe the fc comes in after 480 deg. If it is just a sensor, I’ve got a cm2350 that’s been de mandated from the recommended list on this forum, can I just swap the sensors? It’s the long weekend here in Canada and I won’t be able to get a new one. Ie. is the sensor on the demandated 2350 isx 550 the same and no longer needed on the 2350 so I can swap it to the 2250? | |||
02-18-2023, (Subject: Egr temp high isx 15 ) Post: #2 | |||
RE: Egr temp high isx 15 Well.......... swap them and see !!! User's Signature: im_seeing_parameters_in_my_sleep 1 | |||
02-19-2023, (Subject: Egr temp high isx 15 ) Post: #3 | |||
RE: Egr temp high isx 15 Swapping the sensors worked flawlessly for now. I can only imagine if I didn’t have insite, would’ve cost me 600 easy dollars at Cummins or even a local mechanic, plus driver wages etc. Now it cost me 30 minutes of time. | |||
