need advice
09-16-2016, (Subject: need advice )
RE: need advice
(09-15-2016 )jd870 Wrote:  thanks guy!!!! I'm gonna have a pressure test done..And yes I do a lot of idle truck is constantly on for about 14hrs per day 5-7 days a week I have to run a compressor or product pump for unloading.Any suggestions on where I can get a manual for my engine that wont cost me an arm and 2 legs lol
There are things you can do to reduce wear from so much idling. Raise the RPM above 700, modify the oil pump with 8 dimes, and use a gallon of 80/90 gear lube in the engine at every oil change.
