DIY Flywheel housing gasket/clutch/RMS
05-18-2023, (Subject: DIY Flywheel housing gasket/clutch/RMS )
It’s time. 130k after my inframe and the flywheel housing gasket…or the rear main…is leaking quite a bit. I knew it was coming, so I call to schedule my truck in for that and a clutch too. I think 8 years is a good enough lifespan for one…
…then Haggais tells me they downsized and are no longer taking flywheel housing gasket jobs. Well now I’m back to the drawing board, I’ve never taken my truck to a shop but I was planning on farming that one out.
I’m not aware of anyone in the SE that does work like this that is trustworthy, so I guess it’s time to roll up my sleeves again. Im drawing a blank on the best approach to do this. Tools I have, what I don’t have is heavy equipment like a chain hoist or a trans jack for trucks, though Im never opposed to buying more tools. I know there are some people who do these things like they are candy…Im more worried about it being done correctly.
Who here has done this? Any advice would be great…
RE: DIY Flywheel housing gasket/clutch/RMS
(05-18-2023 )dhirocz Wrote:  It’s time. 130k after my inframe and the flywheel housing gasket…or the rear main…is leaking quite a bit. I knew it was coming, so I call to schedule my truck in for that and a clutch too. I think 8 years is a good enough lifespan for one…
Not sure where you are at but there's a place in St Pauls NC ...
{PM user for the info.}
05-19-2023, (Subject: DIY Flywheel housing gasket/clutch/RMS )
I hate to break it to you but if you want it done 100% right you'll have to do it yourself.
Yeah I figured as much… the more I look at it, the easier it looks. Definitely not as involved as an inframe.
Overhauled @ 927k
05-20-2023, (Subject: DIY Flywheel housing gasket/clutch/RMS )
Where are you located?
05-21-2023, (Subject: DIY Flywheel housing gasket/clutch/RMS )
Depends
If your closet Mississippi I could do it
And buy a new housing, they warp thats why they start leaking
Why they warp idk unless that robot is not torqueing them right
User's Signature: Repairing Demandates 1 Truck At A Time
(05-21-2023 )RollinCoal Wrote:  Depends
The harder the truck in driven, the more the flywheel housing will warp over time due to the twist/stress between the block and tranny under high operating loads.
I.E.> The harder the truck is driven ... + the more torque its set at, the earlier in their lifespan the FWH gasket will start to leak.
 Thanks given by: RollinCoal , RocketScott , snailexpress
05-22-2023, (Subject: DIY Flywheel housing gasket/clutch/RMS )
Makes sense
05-23-2023, (Subject: DIY Flywheel housing gasket/clutch/RMS )
I’m in savannah.
I was able to clean it up and upon closer inspection, it’s definitely the rear seal that’s leaking.
Pulling it down to replace the seal is pretty straightforward I think. What I haven’t figured so far is actually handling the transmission. I’m going to look to see if there are any suitable truck tranny jacks around me for sale, but when the need arises, how have you guys been pulling them?
Overhauled @ 927k
