2018 579 Wipers Only Work on high setting
06-20-2023, (Subject: 2018 579 Wipers Only Work on high setting )
Have a 2018 579 Peterbilt with x15 Cummins. The wipers only work on top 2 high setting. The medium and low settings when used will only move wipers half way then stop. The wiper motor has been replaced. The steering column blinker wiper knob/switch has been replaced. Both fuses were good and also replaced. Any ideas ? Have Cummins insite and ESA.
RE: 2018 579 Wipers Only Work on high setting
(06-20-2023 )BrandonOlsen Wrote:  Have a 2018 579 Peterbilt with x15 Cummins. The wipers only work on top 2 high setting. The medium and low settings when used will only move wipers half way then stop. The wiper motor has been replaced. The steering column blinker wiper knob/switch has been replaced. Both fuses were good and also replaced. Any ideas ? Have Cummins insite and ESA.
I had the identical problem on a Kenworth, it was just a bad relay, it's a cheap and easy thing to replace just to rule it out anyway, on mine there was two relays for the wipers
 Thanks given by: BrandonOlsen
Found the problem. The harness from the wiper motor that goes to the relays ( arrow to where it connects to truck ) had a short inside of the harness. It’s a PITA unwrapping it to replace the damaged wire. The outside of the harness had no visual wear. No rubbing, looked normal. I had googled and looked up different sites where people were reporting this issue but with no resolve. So hopefully this helps someone in need
./uploads/202306/post_6268_1687318079_24e4d9cafe84bf20adb7025d7d92ec3b.jpeg
06-21-2023, (Subject: 2018 579 Wipers Only Work on high setting )
Probably initially caused by the truck owner allowing the truck-wash places to power-wash under the hood, not knowing any better.
Power-washing things under the hood + those connectors = eventual wiring issues with the wiring harnesses... especially where your arrow is pointing.
Here is a similar post for problems in that same connector/area ...
ref: http://rawze.com/forums/showthread.php?t...1#pid12551
