OEM Schematics
09-24-2023, (Subject: OEM Schematics )
OEM Schematics
Does anyone know if there is a website where you can look at OEM Freightliner schematics, similar to Quickserve?
RE: OEM Schematics
Dtna connect- ez wiring. I think you have to call to get set up if you aren’t a corporate user
User's Signature: You can’t buy love, but you can rent it for 3 minutes!
RE: OEM Schematics
If one ask the right person someone may have wall charts and entire electrical and electronics classes straight from freightliner with quiet a few schematics for new cascadias and old that may help you
RE: OEM Schematics
(09-24-2023 )GunRunner Wrote:  Does anyone know if there is a website where you can look at OEM Freightliner schematics, similar to Quickserve?
Website to apply for account
https://dtnacontentdtna.prd.freightliner...ginfo.html
You may get a message like 404 site not found but in the upper right will be a Register Tab and a Log in tab. Click on register.
The VIN you are trying to register has to be in Freightliners system under the same name as you are applying for the account with. To find out call a Freightliner dealer and ask for the warranty coordinator (WC). Doesn’t matter if the truck is out of warranty. The WC is usually a back office person that deals with the nuts and bolts of warranty. IF the truck shows a different owner the WC should be able to update that info. If they won’t there is info on the website if you have to go direct to the website. Should be no charge. The website is going to DTNA which is Daimler Trucks of North America, parent company of Freightliner, Western Star, Thomas etc. In theory you will only be able to access info for your VIN. In practice most all the info is available for the same model. It is kind of like Quick Serve.
Support email is [email protected] HTH
RE: OEM Schematics
Thank you for the info, just registered.
09-25-2023, (Subject: OEM Schematics )
RE: OEM Schematics
Could anybody help with pointing me to where I could get OEM schematics for Volvo? Thanks in advance.
RE: OEM Schematics
Rawze.com does not allow file-sharing of Spirated or Smoofed docs or softSwarez .. on the public side of the forum, so if it is not from an official source.. then don't post it publicly.
RE: OEM Schematics
Volvo body builder site. You might find info there.
https://www.volvotrucks.us/parts-and-ser...r-support/
09-26-2023, (Subject: OEM Schematics )
RE: OEM Schematics
Thanks a lot DVT873. I went to this website before but never looked long enough..... I just generally hate Volvo dealers.....And, of course only official sources!!!
