Coolant shut off to dpf and scr |
10-27-2023, (Subject: Coolant shut off to dpf and scr ) Post: #1 | |||
Coolant shut off to dpf and scr Hi first time posting and looking for information on shutting off the coolant flow to the dpf and scr on my demandated peterbilt 587 2013. When I was under the truck there are 2 3/4 inch hoses one is green the other blue. My question is can I put a shut off there? I just had enough of coolant leaks for something that is visual only. Thank you | |||
10-28-2023, (Subject: Coolant shut off to dpf and scr ) Post: #2 | |||
RE: Coolant shut off to dpf and scr why not just put them together to each other with a single fitting?. User's Signature: ->: What I post is just my own thoughts and Opinions! --- I AM Full Of S__T!. | |||
10-28-2023, (Subject: Coolant shut off to dpf and scr ) Post: #3 | |||
RE: Coolant shut off to dpf and scr Thanks for reply I just thought for looks it would be easier for me to hide them.. Lol but I will do what you suggest and be done with it. Thank you | |||
