2014 T680 and aftermarket LED headlamps - display messages
11-08-2023, (Subject: 2014 T680 and aftermarket LED headlamps - display messages )
I installed some LED headlamps I got from Amazon on my 2014 T680. They are definitely bright! When I go to high beams I get a High Beam Headlamp Fault on my display. Everything works fine but the fault display is annoying. I have Paccar ESA but don't find a place to disable headlamp warnings. Any advice? Other fixes?
01-11-2024, (Subject: 2014 T680 and aftermarket LED headlamps - display messages )
RE: 2014 T680 and aftermarket LED headlamps - display messages
With ESA you need to switch headlights from whatever its set at to LED. Its a dropdown to select it.
 Thanks given by: Pd6cas2
