Tools
09-27-2016, (Subject: Tools )
Post: #19
RE: Tools
(09-26-2016 )Signature620 Wrote:  Can anybody give a comparison between Snap On and IR 3/4" air impacts? I've seen countless Snap Ons that can barely make the torque-turn on ISX head and main bolts.
The only difference I can see is several hundred $$$ .
IR probably makes the snap on impacts, don't know that for a fact.
I've talk to a few guys that bring in piggyback tractors, all of them used the 3/4" IR to dismount and install tires. Good enough to get them on the ground, then final torque.
Post: #20
RE: Tools
I don't use air tools except for the main bearings. it is just too problematic to use wrenches and a torque amplifier upside down under the truck. You end up trying to sling around 20-lbs of wrench and 4 feet of cheater pipes just do the final torque.
got this one...
http://www.northerntool.com/shop/tools/p..._200655835
It will put them in with no problem, but I have the air pressure on the compressor turned up to 150 PSI and feed it with 1/2 line WITHOUT quick-connects, but hydraulic pipe unions instead...
https://amzn.com/B00D3CU5YI
