Speedometer cuts out/in intermittently |
01-02-2024, (Subject: Speedometer cuts out/in intermittently ) Post: #1 | |||
Speedometer cuts out/in intermittently 05 Pete 387 - Cummins isx- zf freedom line auto trans. I have replaced the speed sensor but speedometer/odometer still cuts out. And when the speedometer isn’t working it affects the operation of the auto transmission. After replacing the sensor without results I was going to replace the transmission wiring harness but the harness is not available. Any suggestions will be greatly appreciated | |||
01-02-2024, (Subject: Speedometer cuts out/in intermittently ) Post: #2 | |||
RE: Speedometer cuts out/in intermittently Remove, inspect and repair the harness you have. Their are alot of tools available theses days to take apart/ fix/make your own harness if necessary. Remove the loom and carefully feel/ flex small sections at a time. an internal brake will poke thru insulation while doing this User's Signature: I may be cross eyed, but i don’t cross thread | |||
01-03-2024, (Subject: Speedometer cuts out/in intermittently ) Post: #3 | |||
RE: Speedometer cuts out/in intermittently I think there are 2 sensors that read speed on that trans both at the end by the output I think you can switch the wiring from one to the other try that let us know. | |||
