05 CM870
01-29-2024, (Subject: 05 CM870 )
RE: 05 CM870
That might have a solenoid on the firewall that then sends signal to starter I would check that. If you have power at the starter signal wire on starter solenoid when in crank position it's the starter solenoid at the starter if not work your way back.
 Thanks given by: 3406E
RE: 05 CM870
(01-29-2024 )PolishHammer Wrote:  That might have a solenoid on the firewall that then sends signal to starter I would check that. If you have power at the starter signal wire on starter solenoid when in crank position it's the starter solenoid at the starter if not work your way back.
It doesn't have that ive seen it mostly on older trucks but the starter has something like that on top of the solenoid.The red wire on top of it is where i actually bridge it from. You can view the image i attached
./uploads/202401/post_6775_1706582330_88559c9012ae3f68a3bc87e3db41c018.jpg
RE: 05 CM870
The red wire is not in the that picture that specific wire comes from the truck. If im not wrong its the same wire coming from the ignition switch on truck? Where the circle is on this image is where that red wire screws down to for contact. See attached image
./uploads/202401/post_6775_1706582704_5866929899639ebc1dd93fe7fb054a1e.jpg
01-30-2024, (Subject: 05 CM870 )
RE: 05 CM870
The top one is the safety solenoid. It wants to see clutch pushed in before the truck will start you can check the signal wire on that one to see if you hve power coming from the key when cranked if you do but no power on the starter signal then that's the issue.
 Thanks given by: Rawze , 3406E
RE: 05 CM870
https://duckduckgo.com/?q=safety+somenoi...Wiring.jpg
02-02-2024, (Subject: 05 CM870 )
RE: 05 CM870
Update: So I changed the solenoid on the starter and it still didn't fire up from the switch.
RE: 05 CM870
RE: 05 CM870
[/quote]
so yeah i did find that solenoid on the passenger side. found this wire just hanging there. did not screw it back on because i dont know whats going on. I cleaned up the area but nothing change. I found a 20 amp fuse which wasn't blow for that solenoid. see attached image, thats befor area was cleaned
02-03-2024, (Subject: 05 CM870 )
RE: 05 CM870
Are you sure the ecm or vehicle is not in a starter lock-out condition due to anti-theft?. - Just some thoughts if it is not a wiring issue.
Also, whatever that is unp0lugged, I am sure it was not done like that at the factory. - It also looks like it has been unplugged for a while too, and it just hanging there.
Gotta love mechanics and how lazy they are.
