Twin cam isx 870 |
02-25-2024, (Subject: Twin cam isx 870 ) Post: #1 | |||
Twin cam isx 870 I have a 2007 twin cam isx 870 that since I have owned in the past three years I have had to put three heads on it in witch all have cracked all six injector tubes putting pressure into my cooling system the truck is mandated it is a factory 435 and was told it is turned to 500hp I hope I have all this worded correctly | |||
02-25-2024, (Subject: Twin cam isx 870 ) Post: #2 | |||
RE: Twin cam isx 870 How much max boost is it making? You said it's still mandated, but the horsepower is "turned up" how exactly was that done and by who? | |||
02-25-2024, (Subject: Twin cam isx 870 ) Post: #3 | |||
RE: Twin cam isx 870 I have seen it go to 33 but then comes back to 30 and holds and maybe I have that worded wrong maybe I should have said it’s mandate and I’m not sure on who or how I know my local shop has had a computer on it and in the computer it says that’s what it is at | |||
02-25-2024, (Subject: Twin cam isx 870 ) Post: #4 | |||
RE: Twin cam isx 870 what is the engine ser#?. also, only 33/30 psi boost ... it is in a severe derate. sounds to me like incompetence by whoever is working on it more than anything. make/model truck, maybe some history, etc etc. and if someone changed the program for more HP.. for all anyone knows it could be a program for different injectors and different head, etc. what is the program in it according to Insite?. and are those certified OEM heads from OEM stealers$it?. - if not then your pi$$ing in the wind with garbage any ways. User's Signature: ->: What I post is just my own thoughts and Opinions! --- I AM Full Of S__T!. | |||
