| ISB 6.7 CM2150 problem |
| 04-22-2024, (Subject: ISB 6.7 CM2150 problem ) Post: #1 | |||
| ISB 6.7 CM2150 problem 2011 Freightliner M2 106, 6.7 Cummins ISB CM2150, 90k miles. Bought at an auction in this condition. Idles fine, but can't rev past 900-1000rpm. It starts to sputter and lets out excessive gray exhaust smoke. Turbo spins but no boost. You can hold your hand over the compressor outlet and stop the flow. Did the d3man, along with the DPF/SCR/EGR, which helped a little, but it's still struggling. Pulled the turbo apart, and found the VGT gear to be sticky and misaligned. Realigned and cleaned everything up so the gear moves freely now, and put a new actuator on (calibrated with Insite 8.9). Idles better, but still the same problem. No active codes. Changed oil, filter, and both fuel filters. Did a cylinder cutout test, and each one caused it to run slightly more crappy. Starting to think someone put gas in the tank. Is there anything else I should check? TIA. | |||
| 04-22-2024, (Subject: ISB 6.7 CM2150 problem ) Post: #2 | |||
| RE: ISB 6.7 CM2150 problem (something to eliminate)... Those are the same symptoms that happen when the engine cannot breathe properly .. especially the exhaust. A). Disconnect the exhaust piping behind the turbo and see if it runs and idles up significantly better. B). Next would be to also open up the exhaust manifold to let it breathe (before the turbo) and see if it runs and idles up significantly better. Open a gap between the exhaust manifold and the turbo and run it to see if it goes past 1,000 rpm, runs freely. If the turbo arm itself is locked up at 100% closed, it can cripple the exhaust flow. C). Next would be to do the same for the Intake manifold at the head. - Make sure the intake is not blocked up / impacted with soot, etc. - Those smaller engines have intake heaters that sometimes get blocked up / sooted up real bad. Also do a full EGR tune-up, cleaning out all piping + replace the IMAP and all other relevent sensors.. + ensure the egr valve is not stuck in the fully open position. User's Signature: ->: What I post is just my own thoughts and Opinions! --- I AM Full Of S__T!. | |||
| 04-22-2024, (Subject: ISB 6.7 CM2150 problem ) Post: #3 | |||
| RE: ISB 6.7 CM2150 problem Thanks Rawze. The DPF/SCR have been "disconnected" properly and everything is flowing freely. The EGR has also been properly taken care of with a kit. I did replace the IMAP, because it was reading 0.0 inHg. I can try the turbo thing. I have the air cleaner removed for testing. The turbo spins by hand just fine, and it's turning a few thousand RPM (don't remember how much exactly) at idle. | |||
| 04-23-2024, (Subject: ISB 6.7 CM2150 problem ) Post: #4 | |||
| RE: ISB 6.7 CM2150 problem If the thing has a de-mandate program in it, then the next thing to also do ASAP in fact, is to copy tyhe program out of the ecm and e-mail it to me for a proper review of what someone did in there. MOST de-mandate files are extremely harmful to both the engine and its turbo, shortening their life significantly. It can odten be a cause of the turbo over-spooling and restricting exhaust flow (lowering fuel mileage and causing damage over time) too. ref: http://rawze.com/forums/showthread.php?t...5#pid72945 User's Signature: ->: What I post is just my own thoughts and Opinions! --- I AM Full Of S__T!. | |||
| 04-23-2024, (Subject: ISB 6.7 CM2150 problem ) Post: #5 | |||
| RE: ISB 6.7 CM2150 problem I had Runnin Coal do it. It was way worse before the deman, although it could have been severely screwed up prior. Is it possible that some things could have been copied through to the new tune? | |||
| 04-23-2024, (Subject: ISB 6.7 CM2150 problem ) Post: #6 | |||
| RE: ISB 6.7 CM2150 problem How did the cold and hot side blades look on the turbo? If deposits build up the weight slows the speed and chokes it for air. Was a problem with midrange MaxxForce DT's. Have had them that couldn't get past 1300 RPM. Pull the turbo, block the oil feed and right to high idle, 2800 RPM. Probably not your issue but worth checking. | |||
| 04-23-2024, (Subject: ISB 6.7 CM2150 problem ) Post: #7 | |||
RE: ISB 6.7 CM2150 problem (04-23-2024 )Stovedude Wrote: I had Runnin Coal do it. It was way worse before the deman, although it could have been severely screwed up prior. Is it possible that some things could have been copied through to the new tune? you mean 'running rough'?. not really if he re-made it from scratch.. which he usually does. User's Signature: ->: What I post is just my own thoughts and Opinions! --- I AM Full Of S__T!. | |||
| 04-24-2024, (Subject: ISB 6.7 CM2150 problem ) Post: #8 | |||
| RE: ISB 6.7 CM2150 problem Sorry, my bad. Yes. I did pull the turbo apart and clean all the blades. Everything was pretty sooty. The DPF was completely blocked. Everything is completely open now, turbo spins freely, and VGT gear moves freely. Maybe gas in the fuel tank? | |||
| 04-30-2024, (Subject: ISB 6.7 CM2150 problem ) Post: #9 | |||
| RE: ISB 6.7 CM2150 problem I've had a customer's 6.7 in a RAM pickup that they suspected an employee had filled the diesel tank with gasoline. The truck ran poorly, would hardly rev, had some audible knocking/detonation noises when running, and had a ton of grey smoke from the exhaust. The big red flag for what was causing the issue was when the fuel filter cap on the engine was removed you were overwhelmed by the smell of gasoline. Surprisingly enough, a fresh tank of diesel and 2 new fuel filters and the truck ran fine and they drove it away. | |||
