Cummins X15 after treatment issues
06-21-2024, (Subject: Cummins X15 after treatment issues )
Post: #37
RE: Cummins X15 after treatment issues
Buy new sensors don't clean them.
https://youtube.com/playlist?list=PLKyYV..._g3PCzNY7m
08-23-2024, (Subject: Cummins X15 after treatment issues )
Post: #38
Is the boost pressure set correctly for the HP rating? No boost leaks.
Scrub the above. I forgot your X15 have EGR and different turbo to the AU versions.
Post: #39
(08-23-2024 )alamow Wrote:  Is the boost pressure set correctly for the HP rating? No boost leaks.
FYI:
- Boost (charge flow) settings and ratings are typically vehicle specific, more-so than simply hp/power specific. They are also engine make/model specific too.
Also, the mappings seen in the programming typically cover the entire range of HP ratings for the engine, so no, they are not different when looking a 2 different HP/torque rated files of the same model engine.
03-02-2025, (Subject: Cummins X15 after treatment issues )
Post: #40
Has this issue been resolved? Where do you get your fuel? Are you using i bio blend?
