Code 1896
10-04-2016, (Subject: Code 1896 )
Code 1896
I got this code and truck ran like garbage. Tried to install the newest update per the tree but had problems unlocking the module. Went through the tree any way and of course the egr is sticking a bit. IF the mandates were removed would I still need to replace the egr valve?
User's Signature: I don't know sh!t from shinola!
RE: Code 1896
No. Only you should block it off.
RE: Code 1896
Thanks.
