|     Lost all electrical on start    |
|    07-26-2024, (Subject: Lost all electrical on start )   Post: #1   |  |||
|  Lost all electrical on start    Hey yall,   2010 Pete 386 with a CM871. Lost all electrical power trying to start. Cleaned starter grounds, tightened battery grounds. Had 5v at mega fuse. Took it off, cleaned it, got power back, 12.7 at mega fuse. Tried to crank...same thing, lost all power, 5v at mega fuse. Repeated process 3 times. Out of water, need help lol.  |  |||
|    07-26-2024, (Subject: Lost all electrical on start )   Post: #2   |  |||
|  RE: Lost all electrical on start    bad batteries?.   User's Signature: ->: What I post is just my own thoughts and Opinions! --- I AM Full Of S__T!.  |  |||
|    07-26-2024, (Subject: Lost all electrical on start )   Post: #3   |  |||
|  RE: Lost all electrical on start    Load test the batteries. It means absolutely nothing that your volt meter reads 12.7 volts.     |  |||
|    07-26-2024, (Subject: Lost all electrical on start )   Post: #4   |  |||
| RE: Lost all electrical on start | |||
|    07-26-2024, (Subject: Lost all electrical on start )   Post: #5   |  |||
|  RE: Lost all electrical on start    By mega fuse are you talking about the fuse/breaker that's inside the frame by the starter?   If its dropping to 5v there is probably corrosion inside the wire coating going from it to the batteries somewhere. that breaker supplies power to almost everything in the cab.  |  |||
