A26 oil pressure high |
08-06-2024, (Subject: A26 oil pressure high ) Post: #1 | |||
A26 oil pressure high Hey folks! Anyone have an issue with high oil pressure on the A26 engine? No codes and I’ve already replaced the oil pressure sensor and hooked up a manual gauge to confirm its high. | |||
08-06-2024, (Subject: A26 oil pressure high ) Post: #2 | |||
RE: A26 oil pressure high How high is it? | |||
08-07-2024, (Subject: A26 oil pressure high ) Post: #3 | |||
RE: A26 oil pressure high Pressure is around 40-50 at idle after warm up. Press the gas and it shoots up around 120. Im wondering if its the oil pressure relief valve. | |||
08-08-2024, (Subject: A26 oil pressure high ) Post: #4 | |||
RE: A26 oil pressure high Check the oil sender electrical connector for pushing oil into wiring? | |||
08-08-2024, (Subject: A26 oil pressure high ) Post: #5 | |||
RE: A26 oil pressure high | |||
08-08-2024, (Subject: A26 oil pressure high ) Post: #6 | |||
08-08-2024, (Subject: A26 oil pressure high ) Post: #7 | |||
RE: A26 oil pressure high Im starting to think its the oil pressure relief valve. [/quote] I'd say your probably right. | |||
10-11-2024, (Subject: A26 oil pressure high ) Post: #8 | |||
RE: A26 oil pressure high Recently changed the relief valve but no real change. Still runs wayyyyy up when gas pedal is pressed ☹️ | |||
10-12-2024, (Subject: A26 oil pressure high ) Post: #9 | |||
RE: A26 oil pressure high The pump itself or you got a blockage somewhere. | |||
