CM2250 New Injector, Invalid Barcode.
08-07-2024, (Subject: CM2250 New Injector, Invalid Barcode. )
I just installed a new injector in a CM2250 ISX and it fails to update the injector code. I've tried multiple times so I'm positive that I'm entering it right. Has anyone had this happen and is there a work around?
08-08-2024, (Subject: CM2250 New Injector, Invalid Barcode. )
RE: CM2250 New Injector, Invalid Barcode.
It could be that your ecm needs a software update?.
When as the last time the ecm software was updated?.
What does Insite say is the 'Calibration Software Phase' .. and for 'ECM Code'?.
I flashed the most current Incal in mid June and had Rawze help me with the de-mandate.
I'm running Insite 8.9
