| 2009 Cummins in a Prostar Turbo options |
| 09-03-2024, (Subject: 2009 Cummins in a Prostar Turbo options ) Post: #1 | |||
| 2009 Cummins in a Prostar Turbo options Hypothetically, if you have done a proper delete of the emissions what turbo can you replace the 4800.00 turbo with? International ProStar - 2009 Cummins ISX - 600 | |||
| 09-03-2024, (Subject: 2009 Cummins in a Prostar Turbo options ) Post: #2 | |||
| RE: 2009 Cummins in a Prostar Turbo options Better to keep the stock VGT and have it rebuilt by a reputable builder. | |||
| 09-03-2024, (Subject: 2009 Cummins in a Prostar Turbo options ) Post: #3 | |||
| RE: 2009 Cummins in a Prostar Turbo options YTS Turbochargers Griffin, Ga User's Signature: It's hard to win an argument with a smart person, but it's damn near impossible to win an argument with a stupid person | |||
| 09-03-2024, (Subject: 2009 Cummins in a Prostar Turbo options ) Post: #4 | |||
RE: 2009 Cummins in a Prostar Turbo options (09-03-2024 )cheneygl Wrote: Hypothetically, if you have done a proper delete of the emissions... - that is a loaded statement.. because NO PERSON WHO WOULD RE-PROGRAM THE ECM 100% CORRECTLY AND RELIABLY, would EVER recommend removing that VGT turbo. The ISX engine uses the VGT turbo to set the proper fuel-air-mix. Removing it destroys this and shortens enigne life along with other problems like it costing the average truck more in fuel mileage losses per year than a replacement turbo + loosing the engine brake, etc. Removing it can shorten engine life by as much as half too. Again, due to poor fuel air mix issues and higher liner friction as a result. This especially on higher HP applications. ... so you save $4800 right now so that you can spend $6,000 - $8,000 per year more in fuel + loose the engine brake, + overhaul kits 2x more often due to constant improper fuel-air-mix issues. -- Sounds like some crap someone over on social madai or the youstlubes would say. Only someone who knows nothing of what they are talking about would even suggest it. (09-03-2024 )cheneygl Wrote: ...Yeah.. if it goes bad.. replace it with the same exact model designed for the engine. Lifespan is typically 600k miles (or more if well cared for), even on a properly de-mandated engine. here is some more info on this: https://rawze.com/forums/showthread.php?...9#pid81499 User's Signature: ->: What I post is just my own thoughts and Opinions! --- I AM Full Of S__T!. | |||
