N14 Injector Code-Adjustment
09-19-2024, (Subject: N14 Injector Code-Adjustment )
Hello. I have a 98' N14 Cpl 2391 and Inj code JV
Spec call for Fast= -.359, Slow= -.365, Nominal= -.362
Right now I am at -.360. Is it beneficial/needed to change it to the slow or nominal spec?
Fighting with black smoke and a what I think is a fuel knock only between 1500-1800rpm under load. Rebuilt engine, major out of frame with counterbores, new cam etc. Everything is correct for CPL and ESN. Swapped ECM's with a spare I have and no different. New fuel/filters etc.
I put same gasket thickness on each follower box as what came out, but I am sure this motor was into before.
Thank you.
RE: N14 Injector Code-Adjustment
(this is just my own opinion)...
A person would be hard pressed to find injectors that were not leaky, even certified re-mans, any more that were worth much of anything on that model engine these days.
Also, how do you know its injectors?.. it could be a boost or fuel-air-mix issue just the same.
- I know that some people still try to push those old engines down the roads, but in all reality, old engines like that should be in a museum, or in a collectors truck that does not drive very often, or perhaps used an old RV ... and not hauling any freight on a daily basis due to lack of quality/reliable parts (especially injectors etc.) for them any more. Most people do not get more than a couple three years out of injectors, even when they are good, before they start to act up due to them being re-wokred to death.
