Cm870 Load base speed control
10-10-2024, (Subject: Cm870 Load base speed control )
Hello! I have a cm870 with load base speed control set at 1800. It greatly affects drivability and shifting, making it miserable and aggravating to drive. I have an older version of insite but it states 1800 is the highest it will go. Any help to remedy this would greatly appreciated! Thanks
RE: Cm870 Load base speed control
(10-10-2024 )Zaccattack95 Wrote:  Hello! I have a cm870 with load base speed control set at 1800. It greatly affects drivability and shifting, making it miserable and aggravating to drive. I have an older version of insite but it states 1800 is the highest it will go. Any help to remedy this would greatly appreciated! Thanks
Forum member 'running rough' does all the old 870 custom programming stuffs around here. Maybe get in touch with him if you want it disabled.
In the mean time, maybe the program name, engine ser#, and posting a screen shot or 2 of what your adjusting?
 Thanks given by: Lunchtime92
10-11-2024, (Subject: Cm870 Load base speed control )
Thanks rawze for the reply! The engine serial number is 79228539. I have Cummins insite but it is out of date. I snapped a picture of what I have on insite.
