Cm870 ecm |
Yesterday, (Subject: Cm870 ecm ) Post: #1 | |||
Cm870 ecm 07 Peterbilt. I took a six 870 out and put in 09 isx 871. Will my 870 ECM run the 871? | |||
Yesterday, (Subject: Cm870 ecm ) Post: #2 | |||
RE: Cm870 ecm If its demandated and you use the air actuated turbo off of the 870. You'll need a bit of custom programming. | |||
Yesterday, (Subject: Cm870 ecm ) Post: #3 | |||
RE: Cm870 ecm Yes it's demandated. Swapped turbo off the 870. It runs but the roms and torque are different. What tuning would it need? | |||
Today, (Subject: Cm870 ecm ) Post: #4 | |||
RE: Cm870 ecm Personally, in the case of a CM870(old) to CM871(replacement) engine swap, ... someone would be better off keeping the newer electronic VGT turbo and 871 ecm on it, and adapting it to the vehicle instead. ... and in the case of using the 871 and only downgrading it to the CM870 turbo and ecm .. then yes, custom programming needs to be done due to different compression ratio, different injectors, etc.etc. to get it right. Forum member 'running rough' has experience with 870 - 871 swaps in the past, as he has done this to his own equipment on their farm. He is also able to make the custom settings changes to that CM870 programming if need be. User's Signature: ->: What I post is just my own thoughts and Opinions! --- I AM Full Of S__T!. | |||
Today, (Subject: Cm870 ecm ) Post: #5 | |||
RE: Cm870 ecm (Today )Rawze Wrote: Personally, in the case of a CM870(old) to CM871(replacement) engine swap, ... someone would be better off keeping the newer electronic VGT turbo and 871 ecm on it, and adapting it to the vehicle instead. Any recommendations on where to get programing at? | |||
Today, (Subject: Cm870 ecm ) Post: #6 | |||
RE: Cm870 ecm (Today )Chadillac Wrote: ... get with forum member 'running rough' on here for the CM870 programming. User's Signature: ->: What I post is just my own thoughts and Opinions! --- I AM Full Of S__T!. | |||
