| X15 Power/Noise |
| 01-30-2025, (Subject: X15 Power/Noise ) Post: #1 | |||
| X15 Power/Noise So recently bought a 2019 w9 to add to my fleet and it has a cummins x15 performance series with a 18 speed. My issue is from the day i first hooked a load to it the truck dont seem to run right its tune and deleted from previous owner so its got a knock under load so checked and double checked overheade and gear train. over head good but the cam adjustable idler gear was tight with the cam gear so reset backlash. Next time out still had a knock like before just not as bad but ran with my computer plugged in and found high exhaust pressure and high boost 45psi ish so looked into turbo found it was bad replaced and then retested truck has better power still not where is should be and back pressure is lower (170-179 under load now) also now im running higher coolant temp 200-230 and oil temp 210-240 also i noticed when in the top 4 gears if you push throttle down to half or so i get a motor change and light vibration on the floor but if im on and off a few times it clears up and runs back to its normal self another odd thing is the fan seems to have a mind of its own it comes on as it should when temp is high but at an idle it sometimes will just randomly turn on i love my ISX15 but this new style X15 is giving my a headache any help or direction would be extremely helpful thanks in advance oh and my fuel mileage tanked im loaded both directions and also no im driving a brick pushing the wind but before new turbo was 4.0-4.1 now after turbo 4.3-4.5 and my other trucks are around 5.1-5.5 and they are all bricks to lol | |||
| 01-30-2025, (Subject: X15 Power/Noise ) Post: #2 | |||
| RE: X15 Power/Noise 99% chance you have a bad demandate program in the ECM. Pull a copy of the file out with C A L T E R M and send it to Rawze for review. 45 Pounds of boost will destroy that engine in a hurry!! You say the turbo has been "replaced" does it still have the correct VGT or has someone installed a fixed vane hillbilly truck puller turbo ? | |||
| 01-30-2025, (Subject: X15 Power/Noise ) Post: #3 | |||
| RE: X15 Power/Noise copy program from ecm and e-mail it to me for a review of what someone did in there. info: http://rawze.com/forums/showthread.php?t...5#pid72945 I PM'd you my e-mail address. User's Signature: ->: What I post is just my own thoughts and Opinions! --- I AM Full Of S__T!. | |||
| 01-30-2025, (Subject: X15 Power/Noise ) Post: #4 | |||
| RE: X15 Power/Noise It has been replaced (OEM) i did it and after its been replaced under a hard pull up hill i can almost hit 40 psi | |||
| 01-30-2025, (Subject: X15 Power/Noise ) Post: #5 | |||
| RE: X15 Power/Noise Ill get a copy of it and get it sent out as soon as i can | |||
| 01-30-2025, (Subject: X15 Power/Noise ) Post: #6 | |||
| RE: X15 Power/Noise So i have Calterm and have used it in the past but now im getting wierd message any idea Calterm must exit due to an Unhandled exception | |||
| 01-30-2025, (Subject: X15 Power/Noise ) Post: #7 | |||
RE: X15 Power/Noise (01-30-2025 )DDT LLC Wrote: So i have Calterm and have used it in the past but now im getting wierd message any idea most likely cause: your winblow defender deleted the DLL files that were making it operate correctly. User's Signature: ->: What I post is just my own thoughts and Opinions! --- I AM Full Of S__T!. | |||
| 01-31-2025, (Subject: X15 Power/Noise ) Post: #8 | |||
| RE: X15 Power/Noise Im still having issues with calterm anything else i can use to send you a copy of my ecm | |||
| 01-31-2025, (Subject: X15 Power/Noise ) Post: #9 | |||
| RE: X15 Power/Noise Nope gotta be C A L T E R M. Erase and re install program. Turn off defender, firewall, anti-virus, everything!!! | |||
