N14 diesel in coolant
02-16-2025, (Subject: N14 diesel in coolant )
I took my radiator cap off and there was diesel in the coolant. I was told by a few people that a bad injector cup is the most likely problem. I know there are probably a number of other issues that could cause this problem. Can Cummins Insite help with diagnosing this before taking the head/motor apart? Motor is an N14.
RE: N14 diesel in coolant
No insite can't help you with this. You could pull all the injectors and pressurize the cooling system to 5 psi (no more than 5 psi with injectors removed) and you'll find the leaking cup/cups like that.
 Thanks given by: Jas2153 , hhow55
Yesterday, (Subject: N14 diesel in coolant )
(02-16-2025 )tree98 Wrote:  No insite can't help you with this. You could pull all the injectors and pressurize the cooling system to 5 psi (no more than 5 psi with injectors removed) and you'll find the leaking cup/cups like that.
Thanks. Any recommendations on flushing the radiator/cooling system?
cummins restore, and following their instructions is the best way. Stay away from any kind of soaps in the coolant system.. its a nightmare to get it all out again.
Bad injector cups?
(Yesterday )hhow55 Wrote:  Bad injector cups?
Yes. Found out today.
