|  Looking at a deleted x15  |
|  03-04-2025, (Subject: Looking at a deleted x15 )  Post: #1 | |||
| Looking at a deleted x15  I am in the process of looking at/purchasing a 2019 t800 triaxle dump truck. I am new to this new of a Diesel engine. It has the Cummins x15 and said to be deleted about 2-2.5 years with no problems. All I can say about it is it has 244k miles/ 9400 hrs, it started and ran good, sounded good, about 47 psi oil pressure on cold startup, had very very little blow by after I drove it, the coolant and plastic tank looked clean and the check engine light is on. They have an employed mechanic there and they have Cummins insite. They have not had time to plug in and tell me the check engine light yet but I was planning on going back this week and looking again and going over with the mechanic and hooking to the computer. I was also planning on getting the shops number and asking what their process of deleting is since by reading I guess you can do it different ways by deleting this, blocking this, drilling this, blah blah so I just wanted to ask them. Any of your great knowledge would be appreciated thank you  | |||
|  03-05-2025, (Subject: Looking at a deleted x15 )  Post: #2 | |||
| RE: Looking at a deleted x15  people with bad delete programming usually always swear 'it seems to run good'... until its far too late that is. more than 90%+ of all delete programs area absolutely harmful and damaging to the engine internally over time. 2+ years on an unknown de-mandate, expect that the engine has been heavily abused and in need of an inframe or on the cusp of some other catastrophic damage that has likely already set in. unless someone was willing to copy the program out of it via CT and send it to me for a review to ensure that the de-mandate program is not extremely harmful, .. then I would not give anything more than scrap price for it. ... and just like you mentioned.. if the mechanical stuffs was not done just right too.. then things could be even worse. User's Signature: ->: What I post is just my own thoughts and Opinions! --- I AM Full Of S__T!. | |||
|  03-05-2025, (Subject: Looking at a deleted x15 )  Post: #3 | |||
| RE: Looking at a deleted x15  What do you mean by copy it via CT?  | |||
|  03-05-2025, (Subject: Looking at a deleted x15 )  Post: #4 | |||
| RE: Looking at a deleted x15 (03-05-2025 )TNcoondawg Wrote: What do you mean by copy it via CT? info: http://rawze.com/forums/showthread.php?t...2#pid68742 User's Signature: ->: What I post is just my own thoughts and Opinions! --- I AM Full Of S__T!. | |||
