Pete & KW related Help...
Threads
- 6NZ Cat 2000 (6 Replies)
- Kenworth NavPlus Digital Gauges (7 Replies)
- Heading toward Injector Replacement (4 Replies)
- Kenworth T800 rear engine mounts (8 Replies)
- Dropping the oil pan (25 Replies)
- Kw t660 cooling capacity (3 Replies)
- R134a pressure question (9 Replies)
- Kw T660 axle temp gauge (6 Replies)
- holset turbo engine brake (0 Replies)
- Paccar (14 Replies)
- Holey DPF! (16 Replies)
- 2013 peterbilt 587 isx 15 "fuel rail pressure" (7 Replies)
- Transmission slip? (1 Reply)
- T680 Windows operation without key on (5 Replies)
- Different method to replace spring eye bushings... (0 Replies)
- Isx 400 hesitating (10 Replies)
- Any way to keep front springs from X'ing? (1 Reply)
- A/c failure...of sorts (8 Replies)
- Can't win with new injectors in ISC (14 Replies)
- window problem.. (6 Replies)
- 389 load light fuse location (7 Replies)
- T660 - Side Light / Blinker (19 Replies)
- Air dryer lifespan (2 Replies)
- 2010 389 PETE FIREWALL PASS-THROUGH CONNECTORS (0 Replies)
- 2007 T800 Kw tail light back feed (9 Replies)
